Ana içeriğe geç
SxS not making Ice
Have a whirlpool sxs fridge that worked brilliantly until yesterday when I replaced the water filter. The pump turns on, but there's no water flow to the ice maker. Water dispenser? Works just fine. No jams, no clogs, no power problems. Switch is "on," and the Level Arm is DOWN. I did turn the temp down a couple bard so gonna test that now. Otherwise...STUMPED.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
What is the model number of the refrigerator?
What do you mean by "pump"?
Usually there are three water inlet solenoid valves in a refrigerator with an ice maker and a water dispenser.
A main plus one each for the dispenser and the icemaker.
To get water to flow to each you need two valves to be operated i.e. main + either dispenser or ice maker. Since the dispenser is working OK you may have a problem with the ice maker water inlet solenoid valve or perhaps there may be an airlock (or ice) in the water line to the ice maker, blocking the flow.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
James Boerner sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 103
