Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Soru Tümünü görüntüle
Which direction to pry to remove battery from iPhone 4?
Alright I have followed iFixIt's guide to replace the front assembly on an GSM iPhone 4, but 3 iPhone's I have messed up because of how I removed the battery. The picture on that guide is misleading because it seems like its going the wrong way to pry it. Could someone please instruct me how/which way to pry off the battery from the battery connect, so that it does not break off from the logic board? Thank you so much!
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I put my tool on the side farthest from the battery itself / closest to the left hand side when you're looking down on the phone, just a light lift is all that is needed, obviously, make sure you've removed the screw and that weird little bit of metal that is usually there as well ;) [although I just opened one and it was under the screw, if so, don't worry about removing it until you've un-screwed it]
after that just gently go around the battery from all sides to get it off the glue.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Josh Forester sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 894
