Power issue, not turning on
First time here.
Everything was working fine. Factory reseted and just shut off, not turning back on.
Just checked inside, found a little liquid damage on the board. I dont know where is it from. Disconnected the battery, cleaned the board, connected back the battery, still not registered the power button. Pluged on charger the laptop straight turned on. Turned off and tried again with the battery, not turning on again. Back to the charging cable, turned on.
The indicator is also funny on the charger. Connected the battery and the charger, pressed the power button the indicator changed to orange, released the button the indicator turned to green.
I dont know too much about it but it seems not getting enough power from the battery but the battery was fine, 90% and 570 cycle count.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
tarafından
Yorum Ekle
