Ana içeriğe geç
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
Why do some key take long to use. QWERTYUI
On my macbook air. The top keys of letters are really slow to respond. Sometime it takes really long time! All other keys work.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The keyboard response differs depending on what you are using for an app. As an example filling in a form online can be slow as the connection is either not stable or over a slow link. But the keys across the keyboard should respond the same.
Here you are stating a sub set of keys react oddly, I'm suspecting your battery is pressing on the keyboards cable which is interfering with the signal. To prove it you should see a difference between your systems keyboard vs an external keyboard either a Bluetooth or USB connected.
I would install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question so we can see what the batteries state is.
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
Thank you for the advise. I suspect that the battery is pressing the keyboard cable. I changed the battery and probably in the process I might placed it wrong. I will do the replacement process again.
tarafından
@Ruben Cañas Lindh - Check the keyboard cables connection point on the trackpad MacBook Air 11" Mid 2011 Trackpad Replacement corrosion is also a possibility.
tarafından
Im having trouble puttin the keyboard back on the connection pad. Is there any step-by-step guid to put it pack?
tarafından
@rubl - Post some images of the cable end and the socket so we can see where you are Adding images to an existing question
tarafından
Yorum Ekle
Yanıtını ekle
Ruben Cañas Lindh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 181
