Ana içeriğe geç
Repair guides and support for televisions manufactured by Sony.
748 Soru Tümünü görüntüle
with a led tester the backlight is working fine.
Tapping on my back side of tv (55x9005c) does not solve the issue. The tv is starting and sound is working. With flashlight I can see the menu of the tv. But the backlight is not turning on. with a led tester the backlight is working fine.
which part should I replace?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@harunie check the voltage coming from the power board on the Backlight connectors. If your backlight works with the tester but not with the TV it is possible that this is a power board issue (no voltage or low voltage supplied) or a main board issue. The main board tell s the power board to turn the backlight on. Check the voltage on the connector from main board to power board for the BL ON signal. My prime suspect at this time is the power board. If you need further help on this post some good pictures of your boards with your QUESTION. That way we can see what you see. Adding images to an existing question
Update (05/04/2022)
BL_ON (L or H): IC9017 #18pin should be ~3V
The BL_ON should change when the TV is turning on. That is because it tries to turn the backlight on. If those do not turn on with that signal you would get an error code blinking. Since the BL_ON is generated by the Main board, you should check that next. Post some more very clear and close pictures of your boards. to see if there is /are fuses on the main board. The voltage on the BL should be relatively high so set your meter to the 300VDC range and then bring it down if need should be.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
@oldturkey03
What should be the voltage coming from the psu and the backlight connection?
And what should be the voltage on the connector from main board to power board for the BL ON signal?
tarafından
Yorum Ekle
Yanıtını ekle
Harun sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 218
