Ana içeriğe geç
The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
20 Soru Tümünü görüntüle
How would you fix the left bumper?
The left bumper on my Series controller stopped clicking. The bumper now just squishes and does not record the button press.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
I'd probably guess that replacing the bumpers would help. iFixit sells replacement bumpers here. There isn't a repair guide for this, but you can follow this disassembly guide up to the part where the bumper is removed, swap in the new bumper, and then follow the video in reverse to reassemble. If this doesn't work, your best bet is most likely just sending it to Microsoft for repair, or even just buying a new controller.
Replace your controller's bumper assembly compatible with Xbox Series X model RRT-00010 and RRT-00013 gaming consoles. Fix issues like a cosmetically damaged or bent bumper cover. Görseli
Ürün
Xbox Series X/S Controller Bumper Assembly
$9.99
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Usually just try to replace it (it's actually cheap and available) but if you don't have a good soldering skill you will have nightmares with it
Puan 0
Yorum Ekle
It’s is not pressing down correctly
Puan 0
Yorum Ekle
Yanıtını ekle
David Evans sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 40
Son 30 gün: 203
Her zaman: 11,582
