Ana içeriğe geç
A color version of the Nintendo Game Boy, released in 1998. Repair of this device is straightforward.
Why can’t I start Zelda Links Awakening on the Gameboy?
I recently got a used Gameboy and I decided to get Zelda: Links Awakening DX and it works perfectly up until when the title screen plays after Zelda interacts with Link who is washed upon the shore and I cannot press anything I tried pressing START A B etc. but I’m still stuck at the title screen. Help me?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
7 Yorum
Hello, does this issue happen with any other game or just the one Zelda game?
tarafından
Currently I only own Zelda so I’m not sure
tarafından
@weeatfeet It could be an issue with the game cartridge. See if you can get ahold of a different game and see if that has the same issue.
tarafından
Could it possibly be a problem with the Gameboy? Because I actually bought a used Gameboy from a friend and they never really took care of it so I’m thinking maybe there’s something with the console?
tarafından
@weeatfeet Yes, but ideally external factors should be ruled out when troubleshooting before working on the device itself.
tarafından
2 tane daha yorum göster
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@weeatfeet unlikely that this is caused by a bad cartridge battery. The purpose of the battery in the cartridge is to retain stored memory such as saved games. Of course, try it and see what works. Also, try a different game and remember that if the cartridge is not inserted fully, a poor connection with the Game Boy Color can cause the game to freeze. You also want to clean the cartridge pins use some isopropyl alcohol in a high concentration (like +90% is best, anything lower has way to much water and will not work for this ) and some cotton swabs for the cleaning . Or you can check on here for more ideas.If none of that works, you'll have to actually take a look at the card reader pins etc. Let us know what you find out. Game Boy Color Troubleshooting
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
that sounds like the the save battery is dead on the Gameboy cartridge
Update (06/02/2022)
i had the same problem with a Pokémon yellow i had it was a save battery prob I found they are only supposed work for 2 years but they have been known to work for 10 years depending on how much u play on it
Puan 0
Yorum Ekle
Yanıtını ekle
WeEatFeet sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 644
