Ana içeriğe geç
Repair guides and support for the first generation of Sony's RX100 high-end compact camera with a 20.2 MP sensor. The Sony Cyber-shot DSC-RX100 was released in June 2012.
20 Soru Tümünü görüntüle
How to fix viewfinder not staying down?
Camera fell leaving a dent on the top near the flash, as a result the viewfinder will not stay down. This results in having to use the viewfinder as opposed to the back screen when shooting.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Similar problem here. I once popped out the viewfinder and now it won't retract/kept locked in down position.
Did you find any solution for that problem?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
As a quick fix, you can use a rubber band to keep the viewfinder in. This covers slightly the back screen, but you should be able to still see enough.
I found a small independent repair shop. They opened the camera, and replaced the spring in the viewfinder. They told me it was rusty, due to excessive use in wet/damp conditions (could be well true, as I used the camera also during all sorts of hiking trips). It costs me only 60$, much less than the original Sony repair shop.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Dan Hernandez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 5
Son 30 gün: 9
Her zaman: 102
