Ana içeriğe geç
The Kenmore Elite HE3 is a washing machine by Kenmore.
669 Soru Tümünü görüntüle
flashes Fdl with door open
I just replaced the waterpump,and was testing the washer. When I plugged the washer into a 110 outlet, it flashed FDL. Does this mean I need to replace the lokcing mechanism?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
M Crowell, the error F/dL can be caused by:
"A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure" from the manual.
check all those things out, and you may have to replace the mechanism. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
M Crowell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 436
