Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
Is this a logic board problem?
Hi, ive been having problems with my iPhone 7. It's been having problems with connecting the lightning cable, and battery has been going flat quicky. I can always get it to charge by pulling out the cable, putting it back in, flipping it etc, and it will always work well with a new cable, but somehow I seem to go through a lot of cables quite quickly. They wear out or something.
Naturally, I thought the fix was that I need a new battery and charger port assembly, but before buying the parts, I have opened the phone, and there looks like there has been heat damage or something to the logic board. I was hoping the good people here would look at the photos and be able to tell me if it's a logic board problem or if it's the battery and charger port. Maybe it's a combination...
Anyways, here's the photos.
Thanks for any help. I figure if it's not the logic board, it's worth attempting a fix.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
Could you take a look at your battery again, does it appear to be bulging at all?
tarafından
I don't think so. Looks pretty flat
tarafından
Image added (for the battery)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
If the board looks like that when you open it the first time, someone else has been messing with it.
Judging by the amount of dirt inside a supposedly water resistant phone, someone definitely messed with it before you own it.
The damage on the cable is unlikely to be caused by the board, it looks like corrosion caused by moisture.
Bu yanıt yardımcı oldu mu?
Puan 0
5 Yorum:
Thanks for the answer. I had the screen replaced a while ago.
Do you think the apparent damage to the logic board is water damage?
Can't really comment on the corrosion, I don't really know. but the damage seems to happen to certain pins and not the whole cable head
tarafından
Have you tried cleaning your charging port with a sewing needle?
You will be surprised by the amount of dirt in there!
As for the battery draining ,the iPhone 7 series is getting to a age where there battery’s are going to need replaced
tarafından
@Alexander There is no apparent board damage other than the torn graphite sheet. You can't see most of the board damage unless it is major mechanical damage.
For the cable pin damage. Moisture and electricity combined is required to produce such damage. Only those pins have electricity therefore only they are damaged.
tarafından
Thanks guys.
@hellomacos. Yeah Ive done that. No good results really.
@tom chai. Thanks! Sounds like it's worth giving it a try. I think I will
tarafından
Ah that no good is ,usualy that’s what I found works:-)
tarafından
Yorum Ekle
Yanıtını ekle
Alexander sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 119
