PC won't turn on with or without charger, battery lamp blinking white
I got a notification to replace the laptop battery, so I bought a new battery and adapter. But the laptop wouldn't turn on without charger plugged in, so I plugged in the charger. When charging, the indicator tells it is charging but the battery percentage doesn't increase nor decrease, so I always plug in the charger when I'm using laptop. Every time I plug in the charger, the laptop suddenly turns itself on without me pressing the power button. Then a few days later my laptop wouldn't turn on with or without a charger/battery. Every time I connect the charger, the battery light only blinks white.
I left my laptop for days and after that, I tried to turn it on again with the battery and connected to the charger, it worked, the laptop turned on. But after a while it turns off itself again and when I want to turn it on the same thing happens again, the laptop doesn't turn on and the battery light flashes white. I have try with the old AC and battery, but it is the same, blinking white battery light. Even though I removed the battery, the laptop should be able to turn on if it is connected to a charger, right?Does someone know what went wrong? Please help me.
Actually my laptop is HP Probook 5220m.
Bu iyi bir soru mu?
