Ana içeriğe geç
The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313 Soru Tümünü görüntüle
Trac pad connector MacBook Air connector for new cable popped off
small black flip up and down cable connector which locks cable in place (plastic) broken . I am replacing cable can I tape in place in lieu of trying to get the connector to work?
Thanks in advance, Rich
Update (06/19/2022)
This is the small plastic clip that secures the cable on each end
Sorry had a problem with the photo. As you can see the fastener is tiny and was wondering if I could buy another or tape the cable in place. Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
@poohbeard you can try but most likely it will not provide enough force to maintain the contact. You can try and repair your connector (depends how broke, broke is) or you may have to solder a new connector on. Post some pictures of the damage with your QUESTION so we can see what you see Adding images to an existing question
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Here's the trackpad connector Trackpad Flex Connector I would order a few just in case!
You might be able to carefully unsnap the latch hinge pins on each side by carefully bowing the latch piece. Then you can do the same with the part to then snap into the logic board connector. If you've damaged the lower part of the connector you'll need to desolder the old one and then solder on the new one.
This is a bit tricky! So unless you've soldered logic boards before its best to let someone with the deeper skills do it for you.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks for the link I think I can do as you suggested as the lower part is not damaged. My old eyes need some help with these small pieces :) Really amazing how fragile all these parts are. Thanks, Rich
tarafından
Yorum Ekle
Yanıtını ekle
richard hamilton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 38
