Ana içeriğe geç
GE Mikrodalga Fırın modeli JVM1650BB 007, 1,6 fit küp hacimli, 1000 Watt gücünde ve dışarıya havalandırmalı bir mikrodalga fırındır.
New line fuse needed?
My microwave use ceramic line fuse 20A 250V
Can I use any ceramic fuse if rating is the same even if it is not a line fuse or do I need to use a line fuse?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hi
Do you know for sure it’s the fuse?
To confirm it I would get a multi metre in continuity mode and check for a beep:-)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @k1love
As long as the rating is the same i.e. same volts and amps, that it is a ceramic fuse and that it fits securely into the fuse holder, it will be OK .
If you want the manufacturer's recommended replacement fuse, search online for WB27X10928 to find suppliers of the fuse that suits you best.
There is always a reason why a fuse has blown so perhaps get 2 or 3 just in case you haven't found the reason why the fuse blew as it may happen again soon after you replace it.
Be safety aware when working in a microwave oven. The HV capacitor in the oven can store >6000V DC for months even if the power has been disconnected for this length of time. This amount of voltage can seriously injure you. The HV capacitor needs to be correctly discharged as soon as it can be accessed after the microwave's cover has been removed and before commencing any further work inside the oven.
Protects the microwave from electrical damage by breaking the circuit during power surges or faults. Görseli
Ürün
GE Microwave Fuse - WB27X10928
$18.99
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
KLove sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 443
