My phone is rebooting automatically
When ever I am using my phone it gets switched off and again switched on battery is perfectly alright but still it's like a virus
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
Try using the phone in safe mode and check if the problem still occurs.
If not then a downloaded app is the cause of the problem. The trick is to find out which one.
You will need to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall. When it works OK the last downloaded app that was uninstalled was the cause of the problem. A downloaded app is one that you downloaded and installed and not one that came already installed on the phone.
Bu yanıt yardımcı oldu mu?
I have the same problem and when I used safe mode and went back to normal mode most of the app icons disappeared and so did my wallpaper. Any idea?
Is the phone behaving normally now i.e. not rebooting all the time, even though the apps are no longer on the home screen?
Presumably the apps are still there in the apps menu list?
Going from safe mode back to normal mode should not have altered anything but if there was an app that was causing the initial restarting problem then maybe doing this caused the icons to disappear. I don't know.
All you can do is to place the wanted icons back on the home screen and check if the phone still works OK after turning it off and on again and if so put the wallpaper back again as well.
Thank You so much! How did you discover this?
Windows, Android, Apple, and Linux Operating Systems have a "safe mode" option which allows the user to turn it on to check if it basically works OK or not
This means that only the most basic functions of the device are loaded by the OS software e.g. in Windows PCs the Ethernet (LAN) will work OK so there's an internet connection possible but not the WiFi (WLAN), the screen display will be basic 640 x 480 resolution because no hardware specific video drivers are loaded only generic Windows drivers etc. In Android no 3rd party apps are preloaded when the device is first started.
Each OS is different as to how safe mode operates
Usually if it doesn't work OK in safe mode either then it is a hardware problem. If it works OK in safe mode, usually it is a software problem
Cheers.
Brother try a force reboot this will help you to solve this problem. After it clear the cache of your poco launcher app.
https://howtofixgadgets.com/poco-reboot-...
This will help you to do step by step.
I was having the problem in my poco f1 but now i have successfully solved this problem.
Well this video might be helpful for you: https://www.youtube.com/watch?v=9rSCtcTF...
It might be a tough pill to swallow, still, your phone is going to get bricked soon. Ive tired all most all solutions. Be it master reset, trying in safe mode,uninsatlling the recent update, clearing the theme manager. It had a mother board issue, thats y, poco india head extended its warranty from 12 to 18 months even after the production was stopped. you can check the twitter handle.the soc costs about 10.5 k , but the poco ASC are asking not to proceed.better opt for a new mobile.
Dalla mia esperienza potrebbe essere semplicemente un problema legato al tasto di accensione che monta in sensore touch. Qualcuno più esperto potrebbe dire se questo potrebbe causare il problema?
From my experience it could simply be a problem related to the power button that mounts in the touch sensor. Could someone more knowledgeable tell if this could be causing the problem?
I had the same problem and I thought it was due to a malicious application or something had happened to the board, but I discovered that there was a problem with the power button always pressed, which makes the device always disconnect and turn on. I disassembled the device, then changed the power plug, and now the device works very well
I had the same problem as well got it check via a repair shop and they said the power IC had gone bad and they had to replace it. They did and the phone no longer switches off but I think they did not use original parts so now the phone is laggy and slow, they also forgot to connect the cameras and flashlight. Had to go again to fix that
My phone restarts every day
my phone camera can't take video but can take pictures
It seems the problem is related to the power on / fingerprint reader switch.
I used an earbud cleaner, slightly wet with WD40 Lubricant, very lightly wetting the switch, leave for 5 minutes and wipe dry.
It stopped my continuous boot loop problem
My Poco X3 pro automatic of on new 14 version update plz
Son 24 Saat: 2
Son 7 gün: 25
Son 30 gün: 148
Her zaman: 11,786
1 Yorum
My phone auto restart
Shakir Ali tarafından
