Ana içeriğe geç
Repair and disassembly information for Logitech's G533 wireless gaming headset. The G533 can be identified by its model number A-00072. It was released in January 2017.
Mic doesn’t work
My mic doesn’t work all the time.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
My guess is an intermittent mike may be the result of wire damage. You may have to carefully disassemble the headpiece containing the mike and wiring to examine for wire damage, especially at the point(s) of flex. If visible wire damage isn't seen then a continuity test to each wire of the mike is needed to determine which wire broke inside insulation. Soldering skills would be needed to repair wire damage. If you find and repair damage, try it first before reassembling everything, exercising mike movement to ensure the repair is complete.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
This is not a good question because it gives no history or info relative to when and what was tried to troubleshoot it.
Best guess is a broken lead wire, usually close to an end or connector connection.
Least likely is something internal to the headset unless the mike boom has been move a lot to extreme positions.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
afyuqnjklpi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 86
Her zaman: 2,861
