Ana içeriğe geç
7th Gen Amazon Fire HD Tablet was released June 2017. It has since been discontinued and replaced by the current Fire iteration.
Device not charging after 1%
I plug in my device using several chargers to test if it's the charger is the problem but it won't work. After I plug it in the battery sign show that it's charging and after it turns on at one percent its not charging when it's on and I can't stop it from turning on automatically
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum:
Please answer
tarafından
sounds like u have to take the battery out and put it back it sometimes tablets do this do to their poor design
tarafından
or could be the cord is malfunction that happens to do to another poor design
tarafından
The battery cannot be removed
tarafından
how does it work if there's no way to remove the battery that means there's no way to put it in either? your logic man
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
If it charges in the beginning and you do not move it then there is no reason to think that it is a bad cable or connector.
The most likely issue is a spent battery. See if you can find a battery test app and run that to see what the health of the battery is.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Ok thak you very much
tarafından
how about a rating if it helped?
tarafından
Yorum Ekle
Yanıtını ekle
Millie lee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 1,097
