Ana içeriğe geç
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
20 Soru Tümünü görüntüle
beko fridge freezer too cold
Hi
Beko fridge freezer frost free is too cold that it is making lots ice in the fridge area where it should not make ice. I have defrosted fridge and when it is back on, it starts making ice again. thermostat at minimum. please help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
It sounds like your fridge might need a new tstat, or the damper between fridge and freezer is stuck open, instead of regulating the amount of cold air that enters the fridge section. I'm not familiar with the layout of this particular fridge, as you need to post model number of the unit, but try finding where the cold air enters from the freezer section, and removing panels to access the damper. Try moving the damper yourself by hand. Carefully. Don't bend or break anything doing it.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
I'm so sorry to hear about your issue here. I also faced the same issues. But later on, I noticed that the temperature was so high. And I fixed the issues.
Bu yanıt yardımcı oldu mu?
Puan -1
1 Yorum:
This doesn't help.. what issues did you fix? How did you fix them?
tarafından
Yorum Ekle
Yanıtını ekle
Efe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 529
