beko fridge freezer too cold
Hi
Beko fridge freezer frost free is too cold that it is making lots ice in the fridge area where it should not make ice. I have defrosted fridge and when it is back on, it starts making ice again. thermostat at minimum. please help
Bu iyi bir soru mu?
It sounds like your fridge might need a new tstat, or the damper between fridge and freezer is stuck open, instead of regulating the amount of cold air that enters the fridge section. I'm not familiar with the layout of this particular fridge, as you need to post model number of the unit, but try finding where the cold air enters from the freezer section, and removing panels to access the damper. Try moving the damper yourself by hand. Carefully. Don't bend or break anything doing it.
brandon k tarafından
