How I charge f to c
How I change Fahrenheit to Celsius
Bu iyi bir soru mu?
Here's how to change the passenger compartment temperature display between Fahrenheit and Celsius, if this is what you meant.
To switch the temperature mode between Centigrade to Fahrenheit:
While pressing the MODE button, press the DUAL button for 3 seconds or more.
The display will change from Centigrade to Fahrenheit, or from Fahrenheit to Centigrade
Bu yanıt yardımcı oldu mu?
Do you know if this method also works for Santa Fe 2013/2018?
Hi @erolmacc
On the heater/air con controls press and hold the Off button and then whilst still holding the Off button press the Auto button for >3 seconds and then release. This will change the display from Fahrenheit to Celsius and vise versa.
This is for a Sante Fe 2015
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 46
Her zaman: 6,454
2 Yorum
Hi @baderalbadry
More information is required to help you.
Which temperature indicator do you wish to change in the car?
To convert F° to C° you can always use the formula (F° - 32) x 5/9 = C°
jayeff tarafından
Hi jayff
Yes in my car sonata 1014
Bader tarafından
