Ana içeriğe geç
Repair guides for displays (or monitors) for computers or other devices with video output.
Monitor problem HP 27xq
I have these light streaks that appear in some areas and disappear in the midst of the colors
I never erased the screen and I don't know what to do
And the problem frustrates me in some games when it appears
I want to point out that what I noticed is that these relics were in the form of menu icons for a game I played a lot ( Although it is not very clear, I made sure that it takes the same place and shape as the icons in this game ).
(It is noticeable that this defect does not appear in the five colors R-G-B & Black & Withe = with app UDPixel)
Bu iyi bir soru mu?
Puan 0
3 Yorum
Hi @kinglords
Can you try another monitor to prove whether the problem is in the display or perhaps the computer, GPU for example?
Does it only appear in games?
tarafından
@jayeff
First, thank you for the reply.
- I used another computer with this display and same problem
- I changed the cable from Displayport to HDMI since I relied on Displayport a lot (same problem with HDMI ).
The problem appears all the time, but it is noticeable that the longer i use the screen, the more lines appear, which are basically, as I said, words and icons of the things that I use for a long time.
tarafından
I have the same issue with mine, thought it was something I had done... And its out of warranty now too :(
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@kinglords
It's almost like screen burn in but you'd think that it would be noticeable when testing solid colours as well.
Maybe try a different resolution (frequency refresh rate <144Hz) and check.
If the monitor is no longer covered by the warranty you may have to open it up and check for anything obvious on the control board, although I think that it's more likely to be the LED pixel drivers in the panel, which are internal to the panel
Here's the service manual that may help.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
I changed the screen resolution without any difference
I changed the frame refresh rate without any difference (144Hz - 120Hz - 75Hz - 60Hz)
In the solid color test, the problem is almost not seen, it is there, but you must check to notice it
As for the warranty, it ended. I even tried to open it and only opened the first cover. The truth is that when I completed the rest of the stages, but until here, there was nothing that aroused suspicion.
tarafından
@kinglords
I think that the problem is in the panel as it is always in the same location on the screen.
tarafından
@jayeff yeah I think that (panel )
tarafından
Yorum Ekle
Yanıtını ekle
kinglords sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,047
