Ana içeriğe geç
Released around 2010, the Dell Inspiron 15R N5010 is a 15-inch laptop with an Intel processor and dedicated ATI Radeon graphics card.
My laptop pluged battery light is not blink
my laptop pluged battery light is not blinking
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Check if there is 19.5V DC at the plug at the end of the charger cable to make sure that the charger is OK.
If the charger is OK you need to check if the DC-In jack (supplier example only) on the motherboard is OK. Sometimes the centre pin of the jack breaks internally and this opens the +ve wire of the power supply and the battery can't charge or the laptop can't turn on.
Here's the service manual for the laptop that may help. Click on Systemboard to get to the relevant section in the manual that shows the necessary steps and the procedure to remove the board. This will give access to the DC-In jack so that it can be tested.
If the DC-In jack is faulty it can't be repaired, it has to be replaced.
If the DC-In jack is OK then there's a problem with the motherboard.
If doing this yourself is too daunting, contact a reputable, professional laptop repair service and ask for a quote to fix the laptop.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Raghav Mishra sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 177
