Ana içeriğe geç
Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's ARM-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2338 or EMC 3598.
M1 MacBook screen is black but everything else working
I have a M1 Macbook, it had no damages and everything was fine yesterday evening. No trauma or liquid damage afaik as it was just on the desk. Then suddenly it started going black, first it was every minute or so, in that point closing the display and opening it fixed it.
Then it started turning off every 30 seconds, same thing closing display and opening again fixed it. At this point, connecting to an external monitor worked fine. So on the external monitor I could use it like regular (with mirrored or extended screen).
Then I restarted, tried a bunch of things on the https://support.apple.com/en-ca/HT210905 and https://www.macbookproslow.com/fix-black....
I never got into safe mode or knew if things were working, but I tried all the keyboard combinations. Late into the night, it started working and then I used the Macbook regularly, I went to sleep happy that it was fixed.
Now I woke up and the screen is not working at all, not even showing the apple logo which it was last night. Also, it's not working on external monitor either. I can still see the external monitor and the mouse but it's a black background. The backlight is working and the keys and everything seem fine.
Very frustrating and I'm not sure what to do :(
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
5 Yorum
Hi! This exact thing is happening to me now too. Did you ever get anywhere with the repairs? Thanks!
tarafından
@claireoreilly I had the same issue - I got it repaired by Apple under my AppleCare+ warranty. It cost me nothing.
tarafından
@charliemel65447 what did they say? What is the reason for this issue. Apparently they had fixed the issue in 2018 model but it doesn’t seem to work. Many people are still facing the same issue.
tarafından
I have the same issue. Was working the other night before then suddenly went blank. Screen is on by playing with brightness, you can see it's lighter grey and darker grey. Just nothing shows up on display. Connecting to External display (On mirror) works as well. Tried opening the back to wiggle around with battery and display cable, nothing works.
I do suspect there is something with the 'Angle sensor' which controls the opening and closing of the lid. But I might be wrong.
tarafından
Hey. Same happened to me a few months back. Exactly on March 1, the screen went black never to turn on again. But I kept using it with an external monitor just fine. Tried a bunch of things to fix it – revive the firmware with another Mac, restore it, etc. Nothing worked. I was terrified since I was writing my dissertation project. So I decided to get a new one and left the old at home hooked up to the monitor. I was considering taking it to repair to sell it, but it would cost me an arm and a leg since it's not under warranty anymore. To my absolute surprise, while I was using it this morning, I noticed the screen had come back to life.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Ouch! Not good ;-{
This sounds like the logic board its self has an issue. Either the backlight power which lights up the screen or the graphics services of the M1 SoC.
When you try to turn it on do you see any light glow from the screen (try this is a dark room) Sometimes you can see the screen with change in color slightly grey to black. If you don't then the backlight power logic is a likely suspect.
See if placing a lit flashlight ageists the screen as an angle if you see the faint outline of the desktop icons, if not, then the graphics has a problem.
In either case your system might be covered under warranty. I would visit an Apple Store to see what they say.
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
Hi! I was able to get it working on the external monitor again, that was my bad. Realized I needed to put in the password. Still the same issue on the main screen.
I do see the light light glow, it goes from black to blue when I turn up the brightness. I don't see anything with the flashlight unfortunately :(
tarafından
@Aazir Munir - So when you disconnect the external display (assuming you see your desktop icon's on it) did the internal startup? If not then the internal displays T-CON logic has an issue. That will require a new display assembly MacBook Air 13" (A2337, Late 2020) Display Assembly and here's the guide MacBook Air 13" Late 2020 Screen Replacement
The silver can at the bottom of the display cables is the T-CON unit which is part of the display.
There has been some talk a used display won’t fully work correctly. Some odd artifacts showing up. So be aware of this.
tarafından
Currently having the same issues with my M1. The internal screen is blank and goes from black to blue when I turn up the brightness but the external monitor works perfectly fine.
How were you able to resolve your issue @Aazir Munir?
tarafından
@damilolabello - if the external is working that points to the internal display as I pointed out with Aazir. As you see the Blue color could you have sat something heavy on the system cracking the display? You likely won’t see a physical crack as the LCD glass sandwich back glass is the thinner and do to the chemical process used to make the screen becomes brittle.
Sorry time for a new display assembly as well.
tarafından
Yorum Ekle
I replaced the screen, 1st with an amazon screen then OEM apple screen by reputable repair shop. After replacement, they said screen was black/, off to apple tomorrow for diagnosis. Nothing happenned to this laptop.i am puzzled. Zthe keys backlight works, nothing else
Puan 0
1 Yorum:
That makes sense! All of the M series systems require access to the online Apple configuration tool which is only accessible after you replace the display from Apple directly Apple Self Repair Service.
The bad news is Apple doesn’t offer MacBook repair so you need to use a USED display that has been calibrated already (not new) but! That was for the Intel models not the M series.
So far there is no validated way to replace the display on this series,
tarafından
Yorum Ekle
Yanıtını ekle
Aazir Munir sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 31
Son 7 gün: 190
Son 30 gün: 814
Her zaman: 23,060
