Is there any way to fix the ZIF Connector on an ipad 8?
The ZIF connector that connects my ipad's home button broke off. Is there anyway to repair it or possibly replace it.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If the entire connector was broken off the logic board, it can generally be replaced. But it will require soldering know how to do it. Pictures would help determine if any additional damage was sustained to the board when the connector broke off, since the solder pads which the connector sits on may have come off with the connector. Those can also be repaired if need be. It's just a repair which calls for a specific set of skills.
The connector itself might also be repairable, but it's hard to know without an accompanying visual.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 242
4 Yorum
The whole connectors? Or just the little locking bar?
Alisha C tarafından
Maurico Smith post some pictures of the damaged part etc. with your QUESTION. That way we can see what you see. Adding images to an existing question
oldturkey03 tarafından
The whole connect is completely removed@flannelist
Maurico Smith tarafından
I am unable to post a picture at the moment @oldturkey03
