Ana içeriğe geç
Why does my power button blink 3 times?
i recently found my lost laptop. When i plug in my charger the power button flashes 3 times and then nothing happens from there.
Bu iyi bir soru mu?
Puan 9
1 Yorum
I have the same Issue with my Lenovo X1 carbon 6th. When I press the power button nothing happens. But when I plug in the AC cable the light on the back flash tree times. And there is some sound from the processor.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
For others reading this there are two power staus lights.
One is for the AC power located on the back of the computer.
The other one on the top right from the keyboard is the power on light.
Rick have you tried activating the emergency reset button.
This is located on the bottom of the laptop and can be activated by inserting a paperclip in the hole.
Here are the steps:
  1. Unplug power
  2. Find a thin paper clip
  3. Locate the Emergency Reset Hole on your laptop
  4. Press and hold the Reset Hole for ten seconds with the paper clip
  5. Power on
Bu yanıt yardımcı oldu mu?
Puan 15
9 Yorum:
Hello Mike,
I have the same problem with the same laptop brand.
Lenovo Thinkpad T480. I tried the reset method but nothing changed,
Maybe there is something more i can do to check for the problem.
I will apriciate if u have any other advice.
tarafından
Hi @andreaq,
Some how missed your question.
Here is link to service manual:
https://download.lenovo.com/pccbbs/mobil...
(from page 44) Blinks three times:
• Three Blinks quickly: The computer is entering sleep or hibernation mode.
• Three Blinks slowly: The computer is in sleep mode.
Page 35 explains sleep and hibernation modes.
tarafından
couldn't find the reset button. i just reseat the battery and it was successfully powered on.
tarafından
Yes I found the reset hole in the back of laptop. I inserted the push pin, reset it and it worked for me. Thank you Rick for the post.
tarafından
Thanks a lot, it saved my day as well.
tarafından
4 tane daha yorum göster
Yorum Ekle
Remove/disconnect both batteries. Remove RAM. Disconnect "button battery".
Wait more than 1min.
Reconnect all.
It worked for me.
Puan 0
2 Yorum:
Same symptoms, but pushing (with paperclip) and holding the reset button on the bottom of my Lenovo T16 fixed mine.
tarafından
Emergency reset on bottom of the laptop will only work for about 3 times. So make backups and check for warranty. The second time this happens bring in for repair and demand them to fully boot regularly for about 4 or 5 times after reset.
tarafından
Yorum Ekle
Yanıtını ekle
Rick smith sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 51
Son 7 gün: 550
Son 30 gün: 2,659
Her zaman: 182,204
