My laptop is not turning on yet it is charging
Its only showing its charging
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @otakunoweeb
Try a power refresh in case it is a corrupted BIOS that is preventing the laptop from starting.
If still no good try a full power refresh.
If it turns on OK there might be a message saying that the date and time are incorrect. This is normal as the BIOS has been reset. Once the date and time have been adjusted, the message won't appear the next time the laptop is started. Also if any user defined BIOS settings have been changed by you to suit your particular operating requirements they will have to be changed again as they have been reset.
Bu yanıt yardımcı oldu mu?
My battery is non-removable
If the RTC battery is non removable this means it must be soldered to the motherboard and would be a rechargeable battery, unlike the one used in the answer above which is non rechargeable and therefore fails after some years.
What is the make and model number of your laptop?
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 6,819
1 Yorum
My Lenovo ThinkPad charging but don't open
Mellu tarafından
