Can I change from TN to IPS? same FHD resolution
I have this laptop and i was wondering if i could change the screen to a higher brightness or at least better colors IPS tecnology display
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
Here's a link to the parts list for the model.
Click on Select Commodity > LCD panels (10) to view all the panels compatible with the model.
Not sure which are IPS but the bottom of the list shows 14" FHD IPS AG (part #5D10S68975) with 28 equivalent panels.
Searching for that part number verifies that it is an IPS panel.
Search online using the part number only of the panel that you decide that you want to find suppliers that suit you best.
(If you enter your laptop's serial number (look on info label on bottom of laptop) into the Enter serial number search box on the parts page you should find out the part number of the panel you have.
Here's the hardware maintenance manual for the laptop. Go to p.67 to view the procedure to remove/replace the LCD panel.
Hopefully this is of some help.
Bu yanıt yardımcı oldu mu?
Thank you @jayeff
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 370
