Ana içeriğe geç
De'Longhi BCO430 kahve merkezi, köpürtme çubuğuna sahip, gümüş ve siyah renkli, pompalı espresso ve 10 fincanlık filtre kahve makinesinin birleşimidir.
There fog in my timer
Hello I made a cappuccino and I think some water spilled to the clock and is now foggy how do I fix it ?
Update (10/08/2022)
Can you see the images? not sure if it got uploaded properly
Update (10/08/2022)
Resim
Resim
Resim
Did these images come ok?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi
Unfortunately there aren’t many options
You could leave it in a very dry environment until the moisture drys up
Or you could take it apart and see what the issue is from the inside(eg broken seal)
Unfortunately there aren’t many guides on taking it apart so if you decide to take it apart I can try and help guide you if you would like
Hopefully this helps
Any questions please ask
Bu yanıt yardımcı oldu mu?
Puan 1
8 Yorum:
Can you help me with replacing the boiler lid on this one? I am not able to figure out how to expose the boiler fully so that I can replace it. I am able to access it from the top, but that will not help me remove the boiler. Thanks in advance.
tarafından
@valchrisfamily
If you can upload some photos of what stage of dissasembly you are at using this amazing guide I can try and guide you
Mevcut bir soruya görsel ekleme
tarafından
Uploaded 4 pics. The last one shows a close up
Of the boiler where the water input nut is broken and needs to be replaced.
tarafından
Also - I did open the bottom as on the video. It the video was solving a problem with the drip coffee maker. I could not find a way to open the espresso side of things.
Thanks for any tips.
tarafından
@Valentine Christopher
Thanks for the images(they all came through just fine)
Let’s start by removing the 4 screws on the right side of top of the machine to see if that uncovers anything
(Just to let you know I haven’t actually worked on this specific device ,iv only ever worked on things similar to it, so I’m just using my repair knowledge and priory experience for these sorts of devices)
tarafından
3 tane daha yorum göster
Yorum Ekle
These coffee makers often are similar. Compare to Saeco Magic Capuccino SIN017 Boiler sökme and Starbucks barista , perhaps it helps. Good luck!
Starbucks Barista Görseli
Kılavuz
Starbucks Barista Teardown
Zorluk:
Orta
Saeco Magic Capuccino SIN017 Boiler sökme Görseli
Kılavuz
Zorluk:
Orta
Puan 1
Yorum Ekle
Pics attached - this is how far I could get
Update (10/08/2022)
Puan 0
Yorum Ekle
Update (10/08/2022)
Resim
Resim
Resim
Puan 0
Yorum Ekle
Yanıtını ekle
liluet_hernandez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 508
