iFixit Replacement battery not charging after PRAM reset
I recently replaced my macbook pro 2017 TB battery , everything worked fine after and the battery was charging then suddenly the macbook turned off , I turned it on again and it was charging , I did a PRAM reset as recommended however after it opened up , it says battery is not charging
Update 1 : so I tried removing the back lid again , disconnecting the battery cable and reconnecting it , then turning on my MacBook but this time did no PRAM reset and it charged , so I recharged it to 100% and then used it without the power adapter to drain the battery , after draining it , I connect the power adapter , it turns on but again won't recharge !
Update 2 : I tried entering recovery mode and found out that the battery charges in recovery mode, I turned off the macbook and did a SMC reset then turned it on and again it’s not charging
Update 3 : There is a actually an important detail I forgot to mention, the macbook was subjected to coffee spell , I had it cleaned and then the battery was not charging nor was it booting without the adapter being plugged and the system said faulty battery and that it requires replacement so I replaced it and that was the outcome
Update 4 : I tried to disconnect the battery cable again and test if it recharges properly , It did recharge however after a few seconds the macbook shutdown unexpectedly and when I turned it back on it’s again not charging and just working with Power Source : Power Adapter
Update 5: I found out that only disconnecting the battery flex cable and reconnecting it does nothing , the battery would only charge ( for few minutes) if I remove the battery flex cable AND unscrew the T5 Torx screw and lift up the battery connector , then connect everything back on and turn on the macbook.
Could it be that the battery connector is not aligned properly ? or could it be that I damaged it ?
Bu iyi bir soru mu?
Hi there! I would check the battery status on your MacBook. This article from apple shows you how to
Check the condition of your Mac notebook’s battery
Please let me know the results!
Kuromi tarafından
@pepss - I find Apples battery condition info is too limited! A better tool is to install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question (the base use is free)
Dan tarafından
@pepss, Interesting findings. Personally i haven't run into this before. But, would you happen to have a voltmeter around? That would possibly help with diagnosing the issue but i think i'll leave this one to the experts
Nick P tarafından
unfortunately no
Peter tarafından
Alright that's fine. Have you checked your charger works and is not fried? That's always a possibility. Or maybe the charger is not supplying enough power. Use the original 65W charger to see if it works.
Nick P tarafından
5 tane daha yorum göster
