Why is my keyboard getting hot
Lenovo IdeaPad L340-15IRH GAMING laptop and when i play games the keyboard gets hot. Plus the battery drains to fast can you please help
Bu iyi bir soru mu?
Bu iyi bir soru mu?
First run some diagnostic software like Speccy or HWMonitor to check if the temps are higher than they should, for reference take a look at the values showed in this full review of your laptop ("Temperature" paragraph). In this case, aside from keeping your laptop on a solid, flat surface while it's operating, here are some possible solutions to the laptop's oveheating problems:
Other tricks that will help you keep your system cooler are:
Finally, to get info on your battery's health on Windows, type the "powercfg /batteryreport" command, then simply open the newly created report (it's in your home folder). For more information, check out this article
Hope this helps
Cheers
Bu yanıt yardımcı oldu mu?
I would say problem is that something is using PC a lot. I would check malware or other software to see what is using pc resources a lot and kill that process, then i will not make heat and then it should work bit faster
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 23
Her zaman: 677
