Ana içeriğe geç
Repair information for the Fitbit Sense. A smartwatch with GPS tracker, health and fitness sensors.
Spare LCDs not coming with an NFC cable?
Hi team! I want to replace the display on a Fitbit Sense.
When trying to buy the spare part, most of them look different than what is seen in this guide, seems like they don't come with that second flex cable (for the NFC).
There's 1 supplier I've seen that sells LCD that seems to come with that 2nd NFC cable for the Fitbit Sense, but it's more expensive than the 99% of the other LCDs sold that seem to just come with one display cable.
Will that be a problem and make Fitbit Sense lose NFC/wireless payments if we replace the LCD with such parts? Or is there a way to transfer the NFC cable from the old LCD to the new one? Or do I NEED to buy the LCD with the second cable for NFC included? Or is this maybe a difference between the Fitbit Sense and Fitbit Versa 3? (as the LCDs are advertised as being compatible for these two)
Any thoughts are much appreciated. Thanks in advance! :)
Update (11/23/2022)
Hi everyone! So I received the part I bought from AliExpress with the NFC+LCD. The repair was super easy and straightforward. The NFC is a piece similar to a wireless charge coil from a Samsung phone but tiny. It's adhered to the LCD's back, but it's definitely removable and swappable. So if anyone is in doubt, just get the LCD and swap the original NFC coil onto the new LCD.
Take care! :)
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hi everyone! So I received the part I bouth from AliExpress witht he NFC+LCD. The repair was super easy and straightforward. The NFC is a piece similar to a wireless charge coil from a Samsung phone but tiny. It's adhered to the LCD's back, but it's definitely removable and swappable. So if anyone is in doubt, just get the LCD and swap the original NFC coild onto the new LCD.
Take care! :)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
NFC is usually separate. I'm assuming the seller selling both wants to make more money.
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
Hi Nigel, thanks for your answer! All the videos I've seen from Fitbit Sense display replacement, all of them show two cables attached to the LCD when opened. One for the LCD and another one from the NFC. I wonder if the NFC one can be transferred to the new LCD assembly that doesn't come with one?
For example here at 2:30 you can see what I mean: https://www.youtube.com/watch?v=Kf4auLnX...
tarafından
@Felipe Leal The smaller cable looks to be connected by a FPC connector on the back of the screen. No reason you can't swap it over.
tarafından
Hi Nigel, sorry for the delayed reply. I ended up ordering the one that comes with the NFC cable just in case as it's my first Fitbit LCD repair, but as soon as the part arrives I will try to see if I could've eventually swapped it over and reply here in case someone else has this same question. Thanks!
tarafından
@strongbow Hi again Nigel! So I received the part I bought from AliExpress with the NFC+LCD. You were right, the NFC coil is adhered to the LCD's back, and it's definitely removable and swappable. Thanks!
tarafından
@Felipe Leal No problem. Happy to help.
tarafından
Yorum Ekle
Yanıtını ekle
Felipe Leal sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 10
Son 30 gün: 21
Her zaman: 488
