lid lock engages and disengages constant
Whirlpool wtw4855hw2 lid lock engages and disengages constant no other feature works.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
Here's the tech sheet for the washer.
Run the diagnostics as described in the tech sheet, to find out whether the problem is a lid switch fault (F5 E1) or a lid lock fault (F5 E2).
There's a code chart in the tech sheet that shows how to decode the lights to know what the error code is:
Fill/Sensing + Rinse + Done = F5,
Done = E1.
Spin = E2
In any event unless it is a wiring problem between the control board and the lid lock assembly (see wiring diagram in tech sheet) or a fault in the control board, most probably the lid lock assembly will need to be replaced. The lid switch is also in the lid lock assembly
Here's a link to a supplier that may help, as there's a video in the page that shows how to replace it.
If you determine that the problem is in the lid lock assembly, search online for W11307244 to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 89
