Black Conductive Pad under battery inside rear panel?
Where can you get these one side adhesive conductive copper / aluminium pads or tapes, do you know where ?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The copper helps dissipate heat, like a heatsink. When I work on iPod's, for example the touch 4g, I also add a dab of arctic silver paste since the paste is usually dried up.
You can find adhesive backed copper sheets, just cut to fit, google :
copper foil sheet
Bu yanıt yardımcı oldu mu?
Thanks
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 297
7 Yorum
Is this a necessary component?
Brad tarafından
I think so, because when the battery charges, it heats up. The pad takes the heat and via the body transfers it out of the case.....
Arnoud tarafından
do you mean on back of motherboard or on inside of rear case???
pollytintop tarafından
Inside of rear case behind battery....
Arnoud tarafından
Slide 30 in changing the rear case gives a good view.
Arnoud tarafından
2 tane daha yorum göster
