Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Black Conductive Pad under battery inside rear panel?
Where can you get these one side adhesive conductive copper / aluminium pads or tapes, do you know where ?
Bu iyi bir soru mu?
Puan -1
7 Yorum
Is this a necessary component?
tarafından
I think so, because when the battery charges, it heats up. The pad takes the heat and via the body transfers it out of the case.....
tarafından
do you mean on back of motherboard or on inside of rear case???
tarafından
Inside of rear case behind battery....
tarafından
Slide 30 in changing the rear case gives a good view.
tarafından
2 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The copper helps dissipate heat, like a heatsink. When I work on iPod's, for example the touch 4g, I also add a dab of arctic silver paste since the paste is usually dried up.
You can find adhesive backed copper sheets, just cut to fit, google :
copper foil sheet
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks
tarafından
Yorum Ekle
Yanıtını ekle
Arnoud sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 297
