Ana içeriğe geç
Sega CD model 2, 1993 yılında Sega Genesis II'nin güncellenmiş tasarımına eşlik etmesi için piyasaya sürülen, Sega CD'nin revize edilmiş bir modelidir.
CD drive not spinning
ive found that my sega cd is not reading disks ive had the unit apart and found that the laser will attempt to find the disk but the motor wont spin the caps on the board appear to be fine as do the other components i have attempted to clean the lens to no avail and suggestions as the what the problem could be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Carter Logan make sure that the nylon gears on the the sled drive are in good working order and do not have any broken teeth etc. Make sure they mesh. You also want to check for power on the motor. After that I suggest you check the schematics and measure the caps etc. After all, things are getting a bit weak after 30 years :-) and recapping might just be on order. Use this manual Sega CDto help you with working on your console.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
motor is getting proper voltage and gears are fine im thinking the laser is bad ive read that the motor wont spin if the laser cant find a disk
tarafından
@Carter Logan time to replace it
tarafından
Yorum Ekle
Hi, did you ever find a fix for this?
Puan 0
Yorum Ekle
Yanıtını ekle
Carter Logan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 2,232
