Ana içeriğe geç
Second generation of the Ford Focus.
Can I remove the hub and wheel bearing together when removing them
Can I remove the hub and wheel bearing together when removing them on front drive side it shows people removing bearings first then hub I'm buying the hub and bearings together and it shows both being put on together I have 2005 focus
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
There is an outter and inner wheel bearing the bearings will sometimes slide off with the hub or rotary, a sometimes they are pressed on the axel or spindle. Usually the outer will side of with the hub or axel, the inner bearing is the one that may be more difficult!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Trina Orrico sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 67
