2019 iMac 21.5 inch display fit other year iMac cases
Have a 2019 iMac 21.5 inch display. Will this display fit other 21.5 inch iMacs from 2013 to 2017 tapered case 5mm? Thank you
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@www39 if you just want to know if the display fits the case, then the early 2019 A2116 display should only fit the A1418 mid 2017 case
Bu yanıt yardımcı oldu mu?
Sadly it’s not that simple! There are two variations a standard retina and the newer 4K display. These are not interchangeable. So you are limited.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 58
1 Yorum
What is you goal here? To fix an older system?
Dan tarafından
