KitchenAid Dishwasher KUDM01TJBL0 Drain Pump runs intermittently
I have had similar problems with my kitchenaid (model KUDM01TJBL0) Mine wouldnt drain i pulled the inside apart down to the food chopper and even removed it as it seems i only had 3 of the 4 screws under the strainer thought one may be in there but no luck finding it yet. I also took the drain hose completely off checked where it connected to the dishwasher as well as my sink garbage disposal and no problems there i then ran water wide open through it and got bout a penny sice chunk out and water flowed great through the hose after that. So i put it all back together started a light cycle on the dishwasher to see if it fixed the issue water flowed out as it should. It did through its first rinse cycle. Then it start a wash cycle or whatever the 2nd one is and ran great heated great and then when time to drain it wouldnt drain at all. I noticed where my 2 drain hoses conected one of the male type ends was dripping during the first cycle where it rinsed fine and drained fine. So i disconnected the hoses and held it in my sunk to watch it drain but never would drain at all. The rinse button light flashes and u can NOT cancel it. So i had to redo it all again this time i will hook the drain hose from the dishwasher striaght to my sink disposal since its long enough and fits same as the extended hose. I seen some dishwashers have a flood or leak sensor or aomething to prevent flooding if u do have a leak or anything. I thought maybe since the other hose was leakin during the first drain cycle which did fine then wouldnt drain during the 2nd cycle maybe that was the problem. Atleast i am hoping thats it but would love to know what yall figure out or anyone who has had the same.issue or pointers would be really glad to hear them thanks.
Bu iyi bir soru mu?
