Ana içeriğe geç
The third revision of the classic Xbox Wireless Controller was released in November 2020, bundled with the Xbox Series X and Series S. This controller is backwards compatible with previous Xbox One consoles, and PCs.
20 Soru Tümünü görüntüle
Problem with LT and RT always pressed
The left and right trigger always keep pressed, this problem began when i replace(
solder and desolder) both stick, first right stick and the controller works normally but when i replace the left stick the problem began.
This video show better the problem(this is the official xbox app): https://1drv.ms/v/s!AhpypwlrW5KohIBgdkgz... as you see the lt and rt button keeps pressed but the others works normally and this is another video with other app(the problem is more visible with this): https://1drv.ms/v/s!AhpypwlrW5KohIBhcMTA...
Thanks in advance.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
3 Cevap
Filtre ölçütü:
Check U9 controller on a board. On output should be 1.4V. I have a solution but it's not very nice. Connect output trace with 3.3V. It worked for me but I don't guarantee that it will work for a long time. You could also replace this IC. Problem is that it's a very small piece and it is easy to burn using hotait. Sometimes this IC doesn't have any specifications on it (especially in 1708 and older) so proper resoldering it can be quite tough
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
do you mean inject voltage on the trace to fix it?
tarafından
Yes. It helped. I don't remember where specifically I connected it, it was a long time ago. Maybe before a voltage divisor if there was. I remember that those sensors have common power so if there is no power, they both don't work.
tarafından
Yorum Ekle
WERE you able to fix it?
Puan 0
Yorum Ekle
I just came across this problem on LT and fixed the problem by replacing the U11 component (303 hall effect sensor for the trigger) with an old xbox one controller 304 hall effect sensor.
Puan 0
Yorum Ekle
Yanıtını ekle
rafaeljevi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 31
Son 30 gün: 128
Her zaman: 2,483
