Washer leaks from back
I took shell off ran med load.
Washer has drip under basket where it mounts to 4 support braces. What do I need 2 do?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi,
you may have to tip the washer over and check if you can see exactly where the leak is coming from. Pour a couple of litres of water into the tub and put some food dye in the water as it may be easier to see where it gets through.
If nothing comes out initially, run a cycle that causes the washer to agitate for a minute or so, just in case movement causes the leak and if still no good drain the water and check.
There is a gasket part #16 (Agitator, basket and tub diagram) under the tub where it may be coming from.
Also check the water drain pump connections as well
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 27
3 Yorum
Hi,
What is the model number of the washer?
jayeff tarafından
Hi jayeff. Thanks 4 responding. It's an oldie. Kenmore 110.92273100
Richard Salazar tarafından
@jayeff hi. Kenmore #110.92273100
