Can my phone battery be replaced with a cracked screen?
I googled if I can replace a battery with a cracked screen and everywhere said it needs to be replaced first then the battery can be replaced. Is this true?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
As long as time is taken and work carefully then yes it can be done. I've replaced loads of batteries on phones with cracked screens. Just go easy.
Bu yanıt yardımcı oldu mu?
@strongbow thank you this helps heaps!!
@lacey6816 No problem, just take your time and use heat on the screen for a while to soften the adhesive first.
Hi @lacey6816
You have to remove the screen first to be able to access the battery so that it can be replaced.
Here's the ifixit iPhone 8 Plus Battery Replacement guide that shows the procedure.
If you're going to replace the screen anyway you may as well do it all at once.
Here's the ifixit iPhone 8 Plus LCD and Digitizer Replacement guide. Note the provisos in the Introduction in this guide about replacing the screen.
Ifixit sells parts for the model. They're listeds in the guides.
Kılavuz
Zorluk:
Orta
30 minutes - 2 hours
Kılavuz
Zorluk:
Orta
1 - 2 hours
@jayeff thank youuu!!
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 251
