Ana içeriğe geç
Repair guides and support for Panasonic's Viera line of televisions.
Tc-p50st50 flashes 6 error code
I have a 2012 Plasma that will go into a lockout with 6 error code flashes, I can reset it using the power button on the tv, it will sometimes work for a week following the reset before doing the same thing, the next time the reset may only before a matter of seconds. I have checked the boards for signs of failures with not obvious problems. The troubleshooting for 6 flashes states that the most probably fault is the sc board, with the next most probable being the “a” board. I am uncertain how to determine with certainty which board is causing the problem. I did check the boards for loose screw grounding connections, there are signs of arcing in a few locations. Any help on how to proceed is appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @kwm
Here's an image that shows how to troubleshoot a 6 blink error code to know whether it is the SC board or the A board that is the problem in your model TV.
(click on image)
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thanks I will give that a try,
tarafından
Yorum Ekle
Yanıtını ekle
KevinM sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 406
