Ana içeriğe geç
2nd-generation magnetic AC power adapter for MacBook products, first released in 2012. Not compatible with previous generation systems. Available in 45W, 60W, and 85W versions.
20 Soru Tümünü görüntüle
Check if work with multimeter
Hi everyone,
I have x3 MagSafe 2 - 85W adaptors which I want to sell but I want to be sure they are fully working. I sold my old MacBook and non of my friends have MagSafe compatible Mac so can't check it direct way. I have multimeter at home.
How can I check this charger with multimeter to know if its work or not?
Would appreciate your help
Update (12/09/2022)
@geirandersen I set a multimeter at the setting (see pic) and the it showed 3.1
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@roderos I’ve attached a pinout image for the MagSafe 2 charger.
Test black probe on Ground and red probe on Power. Both Power pins should have very similar output. If there’s a large difference or the voltage if the voltage isn’t ~20V, you have a bad charger. By large difference I mean anything more than a few millivolts.
Bu yanıt yardımcı oldu mu?
Puan 6
16 Yorum:
So the output from both Power pins must be around 20V?
I have 85W charger.
tarafından
@roderos Yes. You can use any of the Ground pins, but both Power pins should have ~20V. Output voltage doesn’t change with Wattage rating. It’s the amperage that it can possibly draw that is higher on the higher rated chargers.
tarafından
@geirandersen just have a chance to test it out now. sorry for silly question, do I need to have charger plugged into the wall to test it?
tarafından
@roderos Yes, the charger must be plugged in to the power, otherwise it has no output ;)
tarafından
@geirandersen thanks :) I tested x3 chargers both pins an all of them show 3.08-3.1 at DC Voltage 20. Does that mean that they work at full power?
tarafından
11 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Yurii Chaikovskyi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 47
Son 30 gün: 246
Her zaman: 9,352
