Ana içeriğe geç
Fisher&Paykel marka üstten yüklemeli bir çamaşır makinesi.
Not completing spin cycle
machine seems unbalanced no matter how often I re arrange the contents. It stops on rinse and beeps, and won’t move forward- progress- with the cycle. Happens more often than not recently.
Unsure why is now unbalanced. Machine is one of the earlier ones (low agitator)
Update (12/19/2022)
F&p Aquasmart WL70T60D 92127-A-NZ
Aso during the rinse and spin it thumps and bashes around really badly before stopping and beeping and the rinse light stays on, or if I progress it to spin does the same until it stops with the spin light on - and the clothes are still wet.
Been doing it for the past 4 washes perhaps.
I have done two auto tub cleans
I have replaced the straps that attach in the four corners but hasn't helped
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Not sure re the model but check if the suspension rods are still attached OK. These are what the straps that you replaced are connected to.
I couldn't find a service manual for your model but I think that this service manual for a comparable USA model might be very close. Run the diagnostics as shown on p.38 to see what error codes if any are shown.
Also here's the parts list for the AU model which may help if you need parts. Search online using the part number to find suppliers.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Suspension rods worn out
The straps dont do much
tarafından Paylaş
Yorum Ekle
Fixed previously - found some used but not too used suspension rods and that worked.
Had already bought and installed new straps.
I had much fun? using jeffs pdf manual and stripping down then cleaning the everything - including waterblasting the bowl and cleaning out the flapper.
All 100% now
Puan 1
1 Yorum:
The suspension rods are springs in this model, no oil like others. If you replaced the rods and it worked, doe that mean the springs or rod itself wear out too? We are doing a deep clean now, and have also replaced the suspension straps. It works much better with new straps, as one was busted. But is still unbalanced at least once or twice a wash.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
robyn.holmes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 70
Her zaman: 4,022
