Ana içeriğe geç
Repair information for the Asus VivoBook laptop series.
Laptop won't turn on, battery light blinking
The model is Asus vivobook 14 m415dao-vips351.
The problem started with random BSOD with random error codes.
Then last time the screen turned off without warning with fan still running. I turned it off by holding power button for a few seconds.
Now it won't turn on at all, but power light is on, and battery light blinking all the time.
How do I start fixing it/figuring out what's wrong with my laptop?
Edit: battery light still blinks even when it's plugged in
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First of all all what do you mean by "random" error codes? So seemingly random to you. Nothing is random with computers. There is always a specific reason. The task is find what it is.
Here are some of the LED codes:
Power indicator
The power indicator lights up when the Notebook PC is turned on and blinks slowly when the Notebook PC is in sleep mode.
Two-color battery charge indicator
The two-color LED provides a visual indication of the battery's charge status.Refer to the following for details:
  1. Solid White : The Notebook PC is plugged to a power source and the battery power is between 95% and 100%.
  2. Solid Orange : The Notebook PC is plugged to a power source,charging its battery,and the battery power is less than 95%.
  3. Blinking Orange : The Notebook PC is running on battery mode and the battery power is less than 10%.
  4. Lights off : The Notebook PC is running on battery mode and the battery power is between 10% to 100%.
So it looks like your battery charge level is low below 10% of full charge.
Is your charger working? Should output approximately 19volts if you have a multimeter. For your laptop just look at the label on the charger itself for the correct amout. Are you using the original ASUS charger?
Leave it plugged in over night to see if it charges. If it you may need a new battery or charger.
This isn't exactly your model but may be similar. Don't take the battery out but just disconnect it as shown in Step 3. Then connect the charger and see if it turns on. If it does then the battery may be the problem. If it doesn't the charger may be the problem. Any blackouts or power surges in your neigbourhood lately ?
Asus VivoBook 14" F412DA Battery Replacement
Let us know how it goes. There may be other possible causes for your problem.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
By random I mean every BSOD shows different error code each time.
Never changed battery or charger since bought. The battery's full. I've done the overnight charging with no result.
Ok thank you I'll try to do something about the battery
tarafından
Yorum Ekle
Hi everyone
Sorry for my bad English
Couple days ago I got same problem
I turn on my nout and didn't touch it about 5 minutes. When I return to my nout, it had black screen and working fun. Nothing else.
Great!
Power led was blinked solid, but battery led was blinked white is about 1 time in 3-4 second
After many attempts to turn on my nout I closed cap and went to sleep
In the morning I decided to try turn on once more. I open cap and press power button. On screen I've got message like about: your bios is damaged and you need to reflash it
Excellent! I downloaded image of bios for my version nout . Write it on fat32 flash drive and plug it to nout
After press power button I've got Nothing.
$@$*! Why I got message at the morning, but didn't get now. After remembering morning actions I remembered what I pressed power button after opening cap.
I tried it! After opening cap I pressed power button and after 1-2 minutes my nout is turned on!
ZAEBIS! I sayed.
That's all folks!
From Russia with Love!
Puan 0
Yorum Ekle
Sorry for my bad English.
This might be a memory problem.
I have a ASUS VivoBook16(I can’t find it on ifixit,so it might be China special?) and I ran the same problem yesterday. I accidentally poured my coffee on the computer.after I cleaned it up,I found the computer didn’t turn on,and the charging light blinks. After looking for some videos on BiliBili (a Chinese video platform),I found a Lenovo laptop owner says it might be a memory problem. After cleaning the socket and pins, system posted and successfully booted into windows
Hopefully this will help you.
Awmc233
Puan 0
1 Yorum:
中文版本:
可能是内存出问题了
我有一台VivoBook16(ifixit上面找不到,我怀疑是中国特供)然后我前几天遇到了一样的问题,我不小心把我的咖啡撒上去了清理后发现不开机,我断开过电池,一开始以为是电池问题,用万用表发现电池电压正常,后来怀疑供电问题可是测量后发现没问题。最后刷B站看到有个人说联想电脑充电灯闪烁不开机是内存问题,我试着拔掉一根内存,然后开机了。清理完拔掉的那根内存并查回去后也正常开机了。(吗的asus的文档根本没有关于充电led灯闪烁的提示,谢谢你啊打人硕)
tarafından
Yorum Ekle
Yanıtını ekle
Anomery sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 133
Her zaman: 13,794
