Ana içeriğe geç
Small fully automatic coffee machines from Melitta. The Melitta Caffeo Solo makes approximately two cups of coffee at a time. Milk foam is only possible with the "Perfect Milk" variants.
Size of the grind
Hi,
I opened the Caffeo Solo for a cleanup and closed it back. Now when the motor grind, the size of the coffee grind is top big and the infusion is not happening. I tried to change the size of the grind, nothing changed.
Thks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Did you open the grinder? Follow this guide, open it and adjust it. This is a good opportunity for a replacement of the grindstones.
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
Thks for the quick answer ! I'll try next weekend and let you know.
tarafından
I followed the tutorial but nothing changed. The size of the grind is still too big. I didn't see where to adjust so it might be that.
tarafından
I don't know why, but this part does not appear in the english translation:
Jura Mahlsteine austauschen
tarafından
If you want to watch the grinder, when opened, use an empty toilet roll.
tarafından
I finally had time to unmount it and managed to fix it. The issue was that I did not screw properly the black ring (size selector) to the grinder. Thank you very much for your help.
tarafından
Yorum Ekle
Yanıtını ekle
Romain sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 33
Her zaman: 449
