Unable to Access any websites I get error message saying Safari can’t
Unable to Access any websites I get error message saying Safari can’t find server.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi
As @flannelist has said it could be to do with your macOS version
It could also be to do with your safari version
On older macs using a different browser that has been updated recently can help this issue
Might also be worth checking you have a good WiFi connection
Hopefully this helps
Any questions please ask
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 34
2 Yorum
What version of macOS are you running?
Alisha C tarafından
Check your IP address and your router address. You may be a victim of a hijack, changing your router address from 192.168.1.1 to a different address, indicating your computer was hijacked, One way to disable this is to disconnect from you lan line and reboot your computer, After booting up, reconnect and check network connections. You might have to power cycle the router too, to get rid of the hijackers address.
F Dryer tarafından
