Ana içeriğe geç
Radeon RX 580, AMD tarafından 18 Nisan 2017'de piyasaya sürülen bir performans segmenti grafik kartıdır. 14 nm işlem süreci üzerine inşa edilmiş ve Polaris 20 grafik işlemcisini (Polaris 20 XTX varyantı) temel alan kart, DirectX 12'yi desteklemektedir.
Graphics card does not work
Graphics card shows no screen even its fans work properly
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 10
5 Yorum
We need more information about this issue ! What system ( motherboard, PSU, slot ) is this system running with different GPU (which one?) ? What monitor and how is connected ? Where did you get this GPU ? ...
tarafından Paylaş
@roboscrap dell t7500
Yes it works with another card
Monitor is connected with DVI
tarafından Paylaş
@zee204 what I can find this system have 1100 Watts PSU, I am not sure what you have connected, but can you disconnect everything ( HDD, SSD, optical drive, etc… ) except motherboard and GPU and try boot up ? Also you can try add this card to the system with the one what is working, boot into the windows and you can check System Preferences.
tarafından Paylaş
Yes my gpu doesn’t show screen but fan is spinning
tarafından Paylaş
My gpu doesn't work , when i turn on my pc it doesn't on , the fans are working like half of second then nothing is going on.
I have rx580 XFX idk what's the peobleme🫩
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@zee204
The PC should also have integrated graphics if it has a Xeon CPU.
Try getting into BIOS on startup and check if the GPU card is being detected.
Connect the monitor to the motherboard's video port, not the GPU card.
If the card is faulty repairing it is very difficult as there's very little to no info regarding schematics, which will be needed to find the problem.
Bu yanıt yardımcı oldu mu?
Puan 2
5 Yorum:
@jayeff
i have already done that
It detects GPU also show its name but not its memory size
tarafından Paylaş
@zee204
Since you can get a display when using the Intel GPU, then with the GPU card also installed check the status of RX 580 GPU in Device Manager > Display Adapters > right click on the RX580 entry > Properties > General tab > Device Status box.
tarafından Paylaş
@jayeff it shows code 43
I also reinstalled driver but it didn't work
tarafından Paylaş
@zee204
Check that the latest drivers are installed for the GPU card.
Go to Device Manager > Display Adapters > right click on the RX580 entry > Update drivers and follow the prompts.
If it says that the latest drivers are installed then check what version are installed - go to Device Manager > Display Adapters > right click on the RX580 entry > Properties > Driver tab and the version number should be shown there.
Compare it to the versions available in the link at the start of this comment.
If the linked drivers are a later version, download them (appropriate OS although Win 10 and 11 seems the same) and install them manually.
If still no good, unistall the GPU card in Device Manager - Device Manager > Display Adapters > right click on the RX580 entry > Uninstall Device and follow the prompts. Restart the PC in the normal manner and Windows will reinstall it again automatically.
If still no good then the card is faulty.
tarafından Paylaş
My graphics card is spinning but it doesn't start the BIOS or even the brand of computer the computer only crashes at startup but if I remove the graphics card the computer turns on
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Zee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 97
Her zaman: 5,501
