Ana içeriğe geç
Released on July 2, 2007, requires screwdrivers to repair.
Why is my laptop not powered on?
I have a small Latitude D430 laptop that I've had for a while and now it won't boot.  The power light comes on for about 3-4 seconds then turns off.
I've tried:
  • Taking out the battery and running it off of AC.  Didn't work.
  • Running off the battery by itself.  Didn't work.
  • Taking out the battery and AC charger, holding the power button for about a minute, then plugging in the AC charger and powering it on.  Didn't work.
  • Tried different RAM.  Didn't work.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @izainfarooq
Try a full power refresh in case it is a corrupted BIOS and check if that resolves the problem.
Here’s the procedure:
a). Disconnect the charger from the laptop if connected.
b). Remove the main battery from the laptop.
c). Disconnect the RTC (Real Time Clock) coin cell battery from the motherboard.
Here’s the service manual for the laptop. Click on the coin cell battery link in the Contents section to go to the section in the manual that shows how to remove it.
When the RTC battery is removed measure its voltage. If it is <2.6V DC replace it. Search online for Dell D430 RTC cmos battery to find suppliers that suit you best.
d.) Press and hold the laptop's Power On button for a full 30 seconds and then release it.
e). Reconnect the RTC battery (or its replacement).
f). Re-assemble the laptop and reinsert the main battery, connect the charger and try to turn on the laptop.
If it starts OK there may be a message about the date and time being incorrect. This is normal as the BIOS has been completely reset back to its default settings. Once the date and time have been adjusted the message won’t appear the next time that the laptop is started.
If you had previously changed any user defined settings in BIOS to suit whatever specific hardware configuration that you had for the laptop, then these will have to be set again.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Zain Farooq sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 158
