Ana içeriğe geç
Samsung's tenth-generation flagship "phablet," with S Pen stylus and 5G capability. Released August 2019.
Can't detected my S-Pen after my Phone has dropped in water.
I'm checking my S-Pen can work properly ,test by another device.
How can I Replace some part that my phone can be use S-Pen again?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @nineonescafe ,
Even though the phone has a IP68 waterproof rating this doesn't mean that it is still completely waterproof. The phone may have been damaged when it entered the water and some may have got in
Check if the liquid damage indicators have changed colour.
If they have then the impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Samsung Galaxy Note10+ 5G guide that may help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Thank's for your kindly @jayeff ,I'll try to fix its. ^_^
tarafından
Yorum Ekle
Yanıtını ekle
P.Rashann sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 1,015
