Ana içeriğe geç
The first generation Honda CRV, produced from 1995 to 2001.
How to repair my shifter
My truck won't go into any gear unless i use the shift lock release button
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
khalif, I think you should combine the two of the questions you are asking. I think there might just be a common connection. I would start with replacing the brake light switch. As you mentioned in your other question, your brake lights do not come on when depressed. If your brake light switch is malfunctioning, your brake lights will not work,nor will your gear shift locking mechanism. Check the wiring on the switch, makes sure it is adjusted right, and you can check it with a multimeter.Replace the switch, re-evaluate and let us know. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
I replaced the brake light switch in my buddy's crv 2001 and still no brake lights? There on but don't Britten up when peddle is pressed no high mount light on though and replaced all bulbs and checked all fuses
Puan 0
3 Yorum:
Did you check the switch to make sure that it is being activated when the pedal is depressed?
tarafından
Ya there is a white pin that pops out when peddle is pressed I replaced it and still nothing
tarafından
Replaced the switch sorry made it sound like I replaced the white pin the way I wrote that
tarafından
Yorum Ekle
Yanıtını ekle
khalif sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 3,244
